주요 콘텐츠로 건너뛰기
Pneumatic Door Closer Replacement
필요한 것
  1. Pneumatic Door Closer Replacement, Pneumatic Door Closer: 1 단계, 이미지 1/2 Pneumatic Door Closer Replacement, Pneumatic Door Closer: 1 단계, 이미지 2/2
    • Identify the broken part of the door.
  2. Pneumatic Door Closer Replacement: 2 단계, 이미지 1/2 Pneumatic Door Closer Replacement: 2 단계, 이미지 2/2
    • Remove the screws from the inner brackets that connect to the door closer using a screwdriver.
  3. Pneumatic Door Closer Replacement: 3 단계, 이미지 1/3 Pneumatic Door Closer Replacement: 3 단계, 이미지 2/3 Pneumatic Door Closer Replacement: 3 단계, 이미지 3/3
    • Remove the screws from the outer bracket that connect to the door closer using a screwdriver.
  4. Pneumatic Door Closer Replacement: 4 단계, 이미지 1/2 Pneumatic Door Closer Replacement: 4 단계, 이미지 2/2
    • Install the inner bracket that attaches to the door closer by screwing the inner part into the wall using a screwdriver.
  5. Pneumatic Door Closer Replacement: 5 단계, 이미지 1/3 Pneumatic Door Closer Replacement: 5 단계, 이미지 2/3 Pneumatic Door Closer Replacement: 5 단계, 이미지 3/3
    • Plug the smallest included screw into the inner bracket to attach the door closer.
  6. Pneumatic Door Closer Replacement: 6 단계, 이미지 1/3 Pneumatic Door Closer Replacement: 6 단계, 이미지 2/3 Pneumatic Door Closer Replacement: 6 단계, 이미지 3/3
    • Close the door.
    • Install the outer bracket that attaches to the door closer by screwing it into the door using a screwdriver.
  7. Pneumatic Door Closer Replacement: 7 단계, 이미지 1/3 Pneumatic Door Closer Replacement: 7 단계, 이미지 2/3 Pneumatic Door Closer Replacement: 7 단계, 이미지 3/3
    • Attach the door closer into the installed outer bracket by plugging the larger included screw into the inner part.
  8. Pneumatic Door Closer Replacement: 8 단계, 이미지 1/2 Pneumatic Door Closer Replacement: 8 단계, 이미지 2/2
    • Make sure the door closes and opens properly.
    • Adjust the hydraulics by loosening or tightening the screw on the top of the hydraulic axle to have optimal performance.
결승점
Abdullah Kaddura
회원 가입일: 02/24/21
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 28
전체 시간: 589
