주요 콘텐츠로 건너뛰기
Pocket Knife Wooden Casing Replacement
필요한 것
  1. Pocket Knife Wooden Casing Replacement, Wooden Casing: 1 단계, 이미지 1/2 Pocket Knife Wooden Casing Replacement, Wooden Casing: 1 단계, 이미지 2/2
    • Trace the knife outline onto wood.
  2. Pocket Knife Wooden Casing Replacement: 2 단계, 이미지 1/2 Pocket Knife Wooden Casing Replacement: 2 단계, 이미지 2/2
    • Cut out the outline of the wood.
    • Cut the height of the wood to the correct measurement.
  3. Pocket Knife Wooden Casing Replacement: 3 단계, 이미지 1/2 Pocket Knife Wooden Casing Replacement: 3 단계, 이미지 2/2
    • Sand the wood so that it is smooth and free of hard edges.
    • For the best result, sand in the direction of the grain as much as possible.
  4. Pocket Knife Wooden Casing Replacement: 4 단계, 이미지 1/3 Pocket Knife Wooden Casing Replacement: 4 단계, 이미지 2/3 Pocket Knife Wooden Casing Replacement: 4 단계, 이미지 3/3
    • Stain and polish the wood so that it is reflects the other side of the knife.
    • Apply another coat after the first coat dries if you want a darker stain.
    • If you get the Stain and Polish on your skin, your skin might be stained for a few days. In this case, make sure you wash thoroughly; Stain and Polish is only toxic if it is ingested.
  5. Pocket Knife Wooden Casing Replacement: 5 단계, 이미지 1/2 Pocket Knife Wooden Casing Replacement: 5 단계, 이미지 2/2
    • Drill four small holes that will go over the extruded parts of the knife.
    • You can accurately mark the positions of the holes by coloring the screw heads with sharpie then stamping them into the wood.
  6. Pocket Knife Wooden Casing Replacement: 6 단계, 이미지 1/3 Pocket Knife Wooden Casing Replacement: 6 단계, 이미지 2/3 Pocket Knife Wooden Casing Replacement: 6 단계, 이미지 3/3
    • Glue the wood to the knife and clean any hard edges or excess glue that comes from this step.
결승점
Meg Dingee
회원 가입일: 01/29/20
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 13
전체 시간: 394
