주요 콘텐츠로 건너뛰기
Pokémon™ GO Plus+ Factory Reset
필요한 것
  1. Pokémon™ GO Plus+ Factory Reset, One Simple Step: 1 단계, 이미지 2개 중 1개 Pokémon™ GO Plus+ Factory Reset, One Simple Step: 1 단계, 이미지 2개 중 2개
    • Press and Hold on the Top Button
    • While still holding the top button, press and hold on the small back button.
    • This button is slightly recessed. You'll likely need to use a paperclip, SIM Eject tool, or other small pinpoint to press this button.
    • Upon pressing and holding the back button you'll feel a short vibration, continue to hold both buttons until you feel a longer vibration which indicates the factory reset is complete. After this you can release all buttons and re-pair it to your device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
David
회원 가입일: 08/27/14
933 평판
안내서 5개를 작성함
4가이드 댓글
Der Guide war gut, doch fehlte zum Lösen meiner Pairingprobleme noch das Löschen des GO Plus+ in den in-game Einstellungen von Pokémon GO als wichtiger Zusatz.
LordP - 답글
I feel the first vibration but I hold it for like 2 minutes and it doesn’t vibrate again. I am trying to factory reset it because it doesn’t work and I’m trying to see if the factory reset will work
Dreepyaway77 - 답글
Did you fix it?
Christian -
I'm having the same issue, I believe mine is related to the battery not being charged enough to do anything. Not sure how I can get a discharged battery to start charging though.
Michael Mullins -
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 110
지난 30일: 506
전체 시간: 18,526
