소개
Many users of the Pokémon GO Plus+ complain about the very bright catch light, follow this guide to learn how to dampen the brightness of the lights.
필요한 것
Flanking both sides of the charging port are J00 Screws. Remove these.
When looking at the front of the device, with the charging point at the bottom the device has a hinge clip and wires on the top right.
With a fingernail or some kind of slim pry tool, gently lift from the bottom left corner.
There is adhesive that is holding the faceplate on, If you have difficulty pulling it off, use a plastic spudger by inserting it in on the bottom left then slowly hinge the device open while applying pressure to the adhesive pad to loosen it.
Once you've got the faceplate off, on the backside of the faceplate you will see a white PCB with 4 J00 screws securing it, remove those 4 screws
There are two alignment posts holding the board in place, while removing the board be careful not to damage these posts
While the flat flex cable can be disconnected, the white wire is soldered to the other side of the board, so be very careful to not damage it.
다른 한 분이 해당 안내서를 완성하였습니다.
