주요 콘텐츠로 건너뛰기
Pokewalker Button Replacement
필요한 것
  1. Pokewalker Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the Screw on the Back of the Pokewalker.
  2. Pokewalker Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the Screw with a Phillips #0 Screwdriver
    • The screw is attached to the rear case with washers. don't worry about losing it.
  3. Pokewalker Button Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the Rear Cover from the Device
  4. Pokewalker Button Replacement: 4 단계, 이미지 1개 중 1개
    • Use the flat end of a Spudger to Remove the Battery
    • Locate the 4 Screws Around the Device
    • Remove all 4 screws with a Y0 Triwing Screwdriver
    • Separate the 2 halves of the Device
    • Do not Separate Completely as the Display is Still Connected by a Ribbon Cable
  5. 이 단계에 사용된 도구:
    • Use a Spudger to Flip the Latch holding the ribbon cable in place and use Tweezers to Pull it out
    • Do not use Excessive force when reinserting the cable, because ribbon cables are fragile
    • Remove the Rubber-button thingy from the upper case
    • I have no idea what that thing is, edit this guide if you do.
    • Remove the 3 Plastic Buttons from the Case
    • It helps that the buttons only go in one way, makes it easier to reassemble
결론
작성자
4다른 기여자 명과 함께
Winni Stuart
회원 가입일: 04/13/14
447 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 16
전체 시간: 843
