주요 콘텐츠로 건너뛰기
Polar V800 Charging Port Cover Replacement
필요한 것
  1. Polar V800 Charging Port Cover Replacement, Watch Band: 1 단계, 이미지 1/3 Polar V800 Charging Port Cover Replacement, Watch Band: 1 단계, 이미지 2/3 Polar V800 Charging Port Cover Replacement, Watch Band: 1 단계, 이미지 3/3
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Charging Port Cover Replacement: 2 단계, 이미지 1/3 Polar V800 Charging Port Cover Replacement: 2 단계, 이미지 2/3 Polar V800 Charging Port Cover Replacement: 2 단계, 이미지 3/3
    • To remove the watch band, pull each end of the watch band away from the watch frame.
  3. Polar V800 Charging Port Cover Replacement, Charging Port Cover: 3 단계, 이미지 1/3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: 3 단계, 이미지 2/3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: 3 단계, 이미지 3/3
    • Take off the charging port cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nick B.
회원 가입일: 04/29/18
387 평판
안내서 1개 작성함
Cal Poly, Team S17-G6, Livingston Spring 2018 Cal Poly, Team S17-G6, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G6
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
where does not procure the battery port cover ?
Chenthill P - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 2,932
