주요 콘텐츠로 건너뛰기
Polar V800 Display Replacement
필요한 것
  1. Polar V800 Display Replacement, Waterproofing Seal: 1 단계, 이미지 2개 중 1개 Polar V800 Display Replacement, Waterproofing Seal: 1 단계, 이미지 2개 중 2개
    • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
    • Ensure your Polar V800 sports watch is powered off before continuing.
    • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
  2. Polar V800 Display Replacement: 2 단계, 이미지 3개 중 1개 Polar V800 Display Replacement: 2 단계, 이미지 3개 중 2개 Polar V800 Display Replacement: 2 단계, 이미지 3개 중 3개
    • Gently separate the watch housing from the back panel.
    • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
  3. Polar V800 Display Replacement: 3 단계, 이미지 2개 중 1개 Polar V800 Display Replacement: 3 단계, 이미지 2개 중 2개
    • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
    • Remove the waterproofing seal.
    • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
  4. Polar V800 Display Replacement, Display: 4 단계, 이미지 2개 중 1개 Polar V800 Display Replacement, Display: 4 단계, 이미지 2개 중 2개
    • Place a T5 torque screwdriver in the upper right and lower left diagonal 4mm screws that hold the white plastic down and rotate the screwdriver to the left, removing the screws.
  5. Polar V800 Display Replacement: 5 단계, 이미지 2개 중 1개 Polar V800 Display Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the display from the board from the top side of the watch, revealing the display connectors underneath.
  6. Polar V800 Display Replacement: 6 단계, 이미지 3개 중 1개 Polar V800 Display Replacement: 6 단계, 이미지 3개 중 2개 Polar V800 Display Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers, gently pull the display wiring out of the two connectors that attach the display to the motherboard.
    • If the wiring isn't coming out very easily, try wiggling it as you pull it out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jarod Lyles
회원 가입일: 04/18/18
835 평판
안내서 5개를 작성함
Cal Poly, Team S17-G6, Livingston Spring 2018 Cal Poly, Team S17-G6, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G6
4 회원들
안내서 8개를 작성함
15가이드 댓글
Please tell me where can I found spare parts for polar v800 ( motherboard,display)
Thank you
Dimitris Karantonis - 답글
Por sin la encontré. Lleva una Sharp LS013B7DH03
ivan.salson -
Please tell me where can I found spare parts for polar v800 ( motherboard,display, also the case and waterproof seal )
Thank you
Alban Cambronero - 답글
I need to bought a lcd for this watch, someone knows where i can buy it ? Best regards
antonio Fernandez - 답글
Same question as above.
Aki Ala-Salomäki - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 51
전체 시간: 9,459
