이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Begin by having the side with volume and power button face up towards you.
Insert a plastic opening tool between the display and the back cover.
Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
이 단계에 사용된 도구:Plastic Cards$2.99-
Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
Gently lift up the battery as you continue to separate the glue from the battery.
Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
Follow the (Black and Red) wires from the battery to the motherboard.
The two wires (Black and Red) must be removed from the motherboard, as they are connected to the battery.
다른 한 분이 해당 안내서를 완성하였습니다.
