주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polaroid A10 Front/Back Camera Replacement
필요한 것
    1. Polaroid A10 Front/Back Camera Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Polaroid A10 Front/Back Camera Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Polaroid A10 Front/Back Camera Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
      • Begin by having the side with volume and power button face up towards you.
      • Insert a plastic opening tool between the display and the back cover.
      • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
      • It is easier to remove the back cover, if the display screen is faced down.
      • The tabs must be released from all four sides before removing the back cover.
      댓글 쓰기
    1. Polaroid A10 Front/Back Camera Replacement, Battery: 2 단계, 이미지 3개 중 1개 Polaroid A10 Front/Back Camera Replacement, Battery: 2 단계, 이미지 3개 중 2개 Polaroid A10 Front/Back Camera Replacement, Battery: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
      • It is better to use a plastic card if you have one.
      • Gently lift up the battery as you continue to separate the glue from the battery.
      • Lift up just enough to see where the glue is, so that you don't bend the battery.
      • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
      댓글 쓰기
    2. Polaroid A10 Front/Back Camera Replacement: 3 단계, 이미지 3개 중 1개 Polaroid A10 Front/Back Camera Replacement: 3 단계, 이미지 3개 중 2개 Polaroid A10 Front/Back Camera Replacement: 3 단계, 이미지 3개 중 3개
      댓글 쓰기
    3. Polaroid A10 Front/Back Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Gently lift the battery up and out of the device.
      댓글 쓰기
    1. Polaroid A10 Front/Back Camera Replacement, Front/Back Camera: 5 단계, 이미지 1개 중 1개
      • The camera head is located on the upper middle section of the device, close to the battery.
      댓글 쓰기
    2. Polaroid A10 Front/Back Camera Replacement: 6 단계, 이미지 2개 중 1개 Polaroid A10 Front/Back Camera Replacement: 6 단계, 이미지 2개 중 2개
      • Start by locating the two left and right screws which hold the camera head in place.
      • Using the Phillip's 000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
      댓글 쓰기
    3. Polaroid A10 Front/Back Camera Replacement: 7 단계, 이미지 3개 중 1개 Polaroid A10 Front/Back Camera Replacement: 7 단계, 이미지 3개 중 2개 Polaroid A10 Front/Back Camera Replacement: 7 단계, 이미지 3개 중 3개
      • Locate the camera ribbon cable that is connected to the motherboard.
      • With a spudger, remove the camera ribbon cable base from the motherboard connector.
      • With one finger, delicately remove the camera ribbon cable by sliding down.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Shilpa Verma
회원 가입일: 01/22/15
353 평판
안내서 3개를 작성함
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 회원
UWT-ROSE-W15S3G3
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 33
전체 시간: 532
