주요 콘텐츠로 건너뛰기
Polaroid A10 Motherboard Replacement
필요한 것
  1. Polaroid A10 Motherboard Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Polaroid A10 Motherboard Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Polaroid A10 Motherboard Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 1개 Polaroid A10 Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 2개 Polaroid A10 Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 3개
    • Take off yellow tapes that are surrounding the motherboard.
    • Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
  3. Polaroid A10 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Polaroid A10 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Polaroid A10 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
  4. Polaroid A10 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Polaroid A10 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
    • Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
    • Use the same soldering tool to unsolder the ground wire.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Polaroid A10 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Polaroid A10 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Gently lift the motherboard up and out of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tracie
회원 가입일: 01/22/15
119 평판
안내서 1개를 작성함
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 회원
UWT-ROSE-W15S3G3
4 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 618
