주요 콘텐츠로 건너뛰기
Polaroid A10 Speakers Replacement
필요한 것
  1. Polaroid A10 Speakers Replacement, Back Cover: 1 단계, 이미지 1/3 Polaroid A10 Speakers Replacement, Back Cover: 1 단계, 이미지 2/3 Polaroid A10 Speakers Replacement, Back Cover: 1 단계, 이미지 3/3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Speakers Replacement, Speakers: 2 단계, 이미지 1/1
    • The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
  3. Polaroid A10 Speakers Replacement: 3 단계, 이미지 1/3 Polaroid A10 Speakers Replacement: 3 단계, 이미지 2/3 Polaroid A10 Speakers Replacement: 3 단계, 이미지 3/3
    • Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
    • Carefully remove the speakers from original position without pulling out the wires.
  4. Polaroid A10 Speakers Replacement: 4 단계, 이미지 1/1
    • Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
    • The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Speakers Replacement: 5 단계, 이미지 1/1
    • Gently lift the speakers up and out of the device.
결론
Koby
회원 가입일: 01/22/15
104 평판
안내서 1개 작성함
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 회원
UWT-ROSE-W15S3G3
4 회원들
안내서 12개 작성하였습니다
댓글 3개
This is not what I meant I wanted to know what to do if the wires came out of the
amirahoresanwo - 답글
If the wires and out of the
amirahoresanwo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 231
