이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Begin by having the side with volume and power button face up towards you.
Insert a plastic opening tool between the display and the back cover.
Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
Carefully remove the speakers from original position without pulling out the wires.
Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
댓글 3개
This is not what I meant I wanted to know what to do if the wires came out of the
If the wires and out of the
Speaker right
