주요 콘텐츠로 건너뛰기
Polaroid Automatic 100 Bellows Replacement
필요한 것
  1. Polaroid Automatic 100 Bellows Replacement, Bellows: 1 단계, 이미지 1/3 Polaroid Automatic 100 Bellows Replacement, Bellows: 1 단계, 이미지 2/3 Polaroid Automatic 100 Bellows Replacement, Bellows: 1 단계, 이미지 3/3
    • Fully extend the bellows by lifting the #1 lever.
    • Remove the camera cover in order to make the camera easier to work with.
    • When collapsing bellows, press down on the metal frame above the bellows.
  2. Polaroid Automatic 100 Bellows Replacement: 2 단계, 이미지 1/1
    • Peel the two battery cable tabs off of the bellows.
  3. Polaroid Automatic 100 Bellows Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    구매
    • Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
    • Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
    • Use the focus bar to extend bellows even further to access screws easier with the screwdriver.
  4. Polaroid Automatic 100 Bellows Replacement: 4 단계, 이미지 1/2 Polaroid Automatic 100 Bellows Replacement: 4 단계, 이미지 2/2
    • Open the back cover by pushing the lever on the bottom towards the left.
  5. Polaroid Automatic 100 Bellows Replacement: 5 단계, 이미지 1/1
    • Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
    • To make the screws easily accessible, close the bellows by pushing on the metal frame.
    • When reassembling, orient the camera so that screws are screwed in downward and stay in place.
  6. Polaroid Automatic 100 Bellows Replacement: 6 단계, 이미지 1/1
    • Carefully use a classic wide metal spudger to bend the tabs of the bellows.
  7. Polaroid Automatic 100 Bellows Replacement: 7 단계, 이미지 1/2 Polaroid Automatic 100 Bellows Replacement: 7 단계, 이미지 2/2
    • Pull the bellow tabs back with long needle nose pliers.
    • Remove the bellows.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Katie Miller
회원 가입일: 04/14/15
680 평판
안내서 5개 작성하였습니다
Cal Poly, Team 4-3, Maness Spring 2015 Cal Poly, Team 4-3, Maness Spring 2015 회원
CPSU-MANESS-S15S4G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 15
전체 시간: 2,068
