소개
This guide will walk you through the steps of replacing the battery on your Polaroid Cube. Make sure the device is completely powered off before disassembly, and that you have all of the required tools.
필요한 것
다른 10명이 해당 안내서를 완성하였습니다.
댓글 13개
Any idea where to find the replacement batteries?
hooverhogg - 답글
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
