주요 콘텐츠로 건너뛰기
Polaroid Cube Lens Replacement
필요한 것
  1. Polaroid Cube Lens Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Lens Replacement: 2 단계, 이미지 1/1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Lens Replacement: 3 단계, 이미지 1/1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Lens Replacement: 4 단계, 이미지 1/2 Polaroid Cube Lens Replacement: 4 단계, 이미지 2/2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Lens Replacement: 5 단계, 이미지 1/1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Lens Replacement: 6 단계, 이미지 1/1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Lens Replacement: 7 단계, 이미지 1/2 Polaroid Cube Lens Replacement: 7 단계, 이미지 2/2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Lens Replacement: 8 단계, 이미지 1/3 Polaroid Cube Lens Replacement: 8 단계, 이미지 2/3 Polaroid Cube Lens Replacement: 8 단계, 이미지 3/3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Lens Replacement: 9 단계, 이미지 1/2 Polaroid Cube Lens Replacement: 9 단계, 이미지 2/2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Lens Replacement: 10 단계, 이미지 1/1
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Lens Replacement, Lens: 11 단계, 이미지 1/2 Polaroid Cube Lens Replacement, Lens: 11 단계, 이미지 2/2
    • Use a J00 screwdriver to unscrew the two circled 3.5mm Phillips-head screws from the circuit board.
  12. Polaroid Cube Lens Replacement: 12 단계, 이미지 1/2 Polaroid Cube Lens Replacement: 12 단계, 이미지 2/2
    • Use a J00 head screwdriver to unscrew the two 3.5mm screws from the circuit board.
  13. Polaroid Cube Lens Replacement: 13 단계, 이미지 1/1
    • Remove the lens from the unscrewed circuit board and replace the broken lens.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Grant Baldwin
회원 가입일: 09/29/16
685 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-2, Harley Fall 2016 IUPUI, Team 3-2, Harley Fall 2016 회원
IUPUI-HARLEY-F16S3G2
4 회원들
안내서 3개 작성하였습니다
댓글 2개
Where can I find a replacement lens for the cube+? I broke the bubble part of the lens
Ben McAlister - 답글
Maybe is posable replace wider view angle lens ? original looks like fpv camera lens foxeer or runcam micro. Possibly Caddx micro cam lens
starsas777 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 35
전체 시간: 2,308
