주요 콘텐츠로 건너뛰기
Polaroid Cube Video Quality Switch Replacement
필요한 것
  1. Polaroid Cube Video Quality Switch Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Video Quality Switch Replacement: 2 단계, 이미지 1/1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Video Quality Switch Replacement: 3 단계, 이미지 1/1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Video Quality Switch Replacement: 4 단계, 이미지 1/2 Polaroid Cube Video Quality Switch Replacement: 4 단계, 이미지 2/2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Video Quality Switch Replacement: 5 단계, 이미지 1/1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Video Quality Switch Replacement: 6 단계, 이미지 1/1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Video Quality Switch Replacement: 7 단계, 이미지 1/2 Polaroid Cube Video Quality Switch Replacement: 7 단계, 이미지 2/2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Video Quality Switch Replacement: 8 단계, 이미지 1/3 Polaroid Cube Video Quality Switch Replacement: 8 단계, 이미지 2/3 Polaroid Cube Video Quality Switch Replacement: 8 단계, 이미지 3/3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Video Quality Switch Replacement: 9 단계, 이미지 1/2 Polaroid Cube Video Quality Switch Replacement: 9 단계, 이미지 2/2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Video Quality Switch Replacement: 10 단계, 이미지 1/1
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: 11 단계, 이미지 1/2 Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: 11 단계, 이미지 2/2
    • Using a J00 head screwdriver, unscrew the 3.46mm screw that connects the top circuit board to the video quality switch board.
  12. Polaroid Cube Video Quality Switch Replacement: 12 단계, 이미지 1/1
    • Remove the circuit board.
  13. Polaroid Cube Video Quality Switch Replacement: 13 단계, 이미지 1/2 Polaroid Cube Video Quality Switch Replacement: 13 단계, 이미지 2/2
    • Using a J00 head screwdriver, unscrew the two 3.46mm screws connecting the video quality switch to the case.
    • Remove and replace the broken video quality switch.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Grant Baldwin
회원 가입일: 09/29/16
685 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-2, Harley Fall 2016 IUPUI, Team 3-2, Harley Fall 2016 회원
IUPUI-HARLEY-F16S3G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 870
