주요 콘텐츠로 건너뛰기
Polaroid One-Step 600 Battery Cartridge Replacement
  1. Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: 1 단계, 이미지 3개 중 1개 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: 1 단계, 이미지 3개 중 2개 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: 1 단계, 이미지 3개 중 3개
    • Open the bottom compartment of the camera by sliding the lever towards the opening.
  2. Polaroid One-Step 600 Battery Cartridge Replacement: 2 단계, 이미지 1개 중 1개
    • Remove old battery/ film cartridge from camera.
  3. Polaroid One-Step 600 Battery Cartridge Replacement: 3 단계, 이미지 1개 중 1개
    • Follow the instructions that came with the new battery/ film cartridge to insert the new cartridge into the camera.
    • Close the battery compartment of the camera.
    • Note: The camera in this picture does not contain a battery.
결승점
다른 14명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Doug Jimenez
회원 가입일: 01/21/10
556 평판
안내서 2개를 작성함
Cal Poly, Team 16-31, Maness Winter 2010 Cal Poly, Team 16-31, Maness Winter 2010 회원
CPSU-MANESS-W10S16G31
4 회원들
안내서 9개를 작성함
15가이드 댓글
It worked but its expensive
Jessica diaz - 답글
I put new film in, it´s turning on, the flash is going off, but no film is coming out after the flash. What is the problem?
tristanmoeller2013 - 답글
nothing happened
new film installed
no sound
no flash
no action
eminickstone - 답글
I'm having the same issue
Marie -
I'm having same issue.
Marie -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 50
지난 30일: 365
전체 시간: 156,470
