주요 콘텐츠로 건너뛰기
Polaroid One-Step 600 Lens Replacement
필요한 것
  1. Polaroid One-Step 600 Lens Replacement, Lens: 1 단계, 이미지 1/3 Polaroid One-Step 600 Lens Replacement, Lens: 1 단계, 이미지 2/3 Polaroid One-Step 600 Lens Replacement, Lens: 1 단계, 이미지 3/3
    • Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal.
  2. Polaroid One-Step 600 Lens Replacement: 2 단계, 이미지 1/3 Polaroid One-Step 600 Lens Replacement: 2 단계, 이미지 2/3 Polaroid One-Step 600 Lens Replacement: 2 단계, 이미지 3/3
    • Separate the flash section of the camera from the main body by unhooking the sides with the spudger.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Polaroid One-Step 600 Lens Replacement: 3 단계, 이미지 1/3 Polaroid One-Step 600 Lens Replacement: 3 단계, 이미지 2/3 Polaroid One-Step 600 Lens Replacement: 3 단계, 이미지 3/3
    • Fully open the battery/ cartridge compartment by sliding the side tab toward you.
  4. Polaroid One-Step 600 Lens Replacement: 4 단계, 이미지 1/3 Polaroid One-Step 600 Lens Replacement: 4 단계, 이미지 2/3 Polaroid One-Step 600 Lens Replacement: 4 단계, 이미지 3/3
    • Insert spudger in between face of camera and sides where the four tabs are located.
    • BE CAREFUL! The button that is pressed to take a picture may pop out of the camera at this step.
  5. Polaroid One-Step 600 Lens Replacement: 5 단계, 이미지 1/2 Polaroid One-Step 600 Lens Replacement: 5 단계, 이미지 2/2
    • Once tabs are released, pull face of camera straight out.
  6. Polaroid One-Step 600 Lens Replacement: 6 단계, 이미지 1/1
    • Use spudger to twist the notch on the lens into the opening to remove it.
  7. Polaroid One-Step 600 Lens Replacement: 7 단계, 이미지 1/2 Polaroid One-Step 600 Lens Replacement: 7 단계, 이미지 2/2
    • Carefully use spudger to release lens, then lift lens out of camera with fingers.
    • CAUTION: LENS MAY POP OUT OF CAMERA; REMOVE CAREFULLY.
  8. Polaroid One-Step 600 Lens Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Clean old lens with a microfiber cloth or get a new lens to put back into the camera.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Doug Jimenez
회원 가입일: 01/21/10
538 평판
안내서 2개 작성하였습니다
Cal Poly, Team 16-31, Maness Winter 2010 Cal Poly, Team 16-31, Maness Winter 2010 회원
CPSU-MANESS-W10S16G31
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Hi, since you seem to know stuff about Polaroid cameras, I was wondering if you could help me figure out what is wrong with mine. I have a Polaroid Instant One-Step and whenever I take pictures, they never fully develop. They are a blue-ish hue and are never clear. Is this because of the lens do you think? Or something completely different?
Thanks
H.Rose - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 33
전체 시간: 16,116
