소개
If you need to replace the film door latch, use this guide to access the inside of the camera. You may need to replace the latch if your camera will not close.
필요한 것
Unscrew the four 5mm screws on the base of the camera using a Phillips #0 screwdriver.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
This doesn’t actually say anything about replacing the latch…
But where do you buy a replacement latch?
