소개
If you need to replace the film roller, access the inside of the camera using this guide. You may need to replace the roller if the pictures are jammed or if the roller is broken. For this guide you will not need to do any difficult steps, but you will need tweezers.
도구
부품
지정된 부품이 없습니다.
Lift out the top roller. The gold and black pieces will remain attached to the roller.
how do you put the roller back in? I tried to do it but I dont know what to do with the springs, they are attached only to the roller and they are loose
다른 11명이 해당 안내서를 완성하였습니다.
댓글 4개
Hi @abbyboucher Thanks a lot for the tutorial! Do you know where can I find the spare parts like the rollers, springs or the small plastics parts that are around?My Onestep+ fell to the ground and I lost some of those small parts.
Thanks
Joe
Thank you so much for this tutorial! I couldn’t find a place that would fix my camera and I literally just bought it a month ago! Already gutted that I couldn’t bring it on my Christmas holiday, I almost gave up when repair shops told me I would have to contact Polaroid.. thank you so so much!
drummagal7 - 답글
