주요 콘텐츠로 건너뛰기
Polaroid OneStep 2 Flash Cover Replacement
필요한 것
  1. Polaroid OneStep 2 Flash Cover Replacement, Flash Cover: 1 단계, 이미지 1/3 Polaroid OneStep 2 Flash Cover Replacement, Flash Cover: 1 단계, 이미지 2/3 Polaroid OneStep 2 Flash Cover Replacement, Flash Cover: 1 단계, 이미지 3/3
    • Unscrew the four 5mm screws on the base of the camera. Remove the two pieces of the base.
  2. Polaroid OneStep 2 Flash Cover Replacement: 2 단계, 이미지 1/3 Polaroid OneStep 2 Flash Cover Replacement: 2 단계, 이미지 2/3 Polaroid OneStep 2 Flash Cover Replacement: 2 단계, 이미지 3/3
    • Unscrew the four 5mm screws on the top of the inside base piece.
    • Unscrew the two 5mm screws on the bottom of the inside base piece which is near the strap.
  3. Polaroid OneStep 2 Flash Cover Replacement: 3 단계, 이미지 1/1
    • Remove the inside black base piece.
  4. Polaroid OneStep 2 Flash Cover Replacement: 4 단계, 이미지 1/2 Polaroid OneStep 2 Flash Cover Replacement: 4 단계, 이미지 2/2
    • With force separate the front white piece from the back of the camera. You will use your hands to pull it apart.
  5. Polaroid OneStep 2 Flash Cover Replacement: 5 단계, 이미지 1/2 Polaroid OneStep 2 Flash Cover Replacement: 5 단계, 이미지 2/2
    • Forcefully pull on the flash cover until it is removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Abby Boucher
회원 가입일: 09/10/18
811 평판
안내서 5개 작성하였습니다
University of Alabama, Team S1-G1, Bedsole Fall 2018 University of Alabama, Team S1-G1, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 1,472
