주요 콘텐츠로 건너뛰기
Polaroid Onestep Close Up Primary Lens Replacement
필요한 것
  1. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: 1 단계, 이미지 3개 중 1개 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: 1 단계, 이미지 3개 중 2개 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: 1 단계, 이미지 3개 중 3개
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: 2 단계, 이미지 2개 중 1개 Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: 2 단계, 이미지 2개 중 2개
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: 3 단계, 이미지 3개 중 1개 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: 3 단계, 이미지 3개 중 2개 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: 3 단계, 이미지 3개 중 3개
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Primary Lens Replacement, Primary Lens: 4 단계, 이미지 1개 중 1개
    • Once the front assembly is removed, the primary lens should be exposed without any trouble.
  5. Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: 5 단계, 이미지 2개 중 1개 Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: 5 단계, 이미지 2개 중 2개
    • Use your spudger to leverage the lens from the groove at the top (red).
    • Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Christopher Collazo
회원 가입일: 09/22/14
318 평판
안내서 2개를 작성함
USF Tampa, Team 3-5, Brown Fall 2014 USF Tampa, Team 3-5, Brown Fall 2014 회원
USFT-BROWN-F14S3G5
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 15
전체 시간: 1,712
