주요 콘텐츠로 건너뛰기
Polaroid P902 Motherboard Replacement
필요한 것
  1. Polaroid P902 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
  2. Polaroid P902 Motherboard Replacement: 2 단계, 이미지 1/1
    • Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
  3. Polaroid P902 Motherboard Replacement: 3 단계, 이미지 1/2 Polaroid P902 Motherboard Replacement: 3 단계, 이미지 2/2
    • Using the PH00 screwdriver, unscrew the four 4.4 mm screws that are anchoring the circuit board down to the rest of the tablet.
  4. Polaroid P902 Motherboard Replacement: 4 단계, 이미지 1/1
    • Using your fingernail, gently lift up the connectors on the two tabs that are holding the ribbons in place to the circuit board.
    • Be careful when pulling out or reconnecting the ribbons, since if the ribbon or connectors break, they are hard to fix.
  5. Polaroid P902 Motherboard Replacement: 5 단계, 이미지 1/3 Polaroid P902 Motherboard Replacement: 5 단계, 이미지 2/3 Polaroid P902 Motherboard Replacement: 5 단계, 이미지 3/3
    • Using a soldering iron, desolder the points circled on the picture until the solder have liquefied enough to be able to remove the wires from the circuit board.
  6. Polaroid P902 Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently lift the circuit board from the housing. You have now successfully removed the circuit board. Now, you can insert the new board to the tablet.
결론
Mina Tobeck
회원 가입일: 03/26/18
133 평판
안내서 1개 작성함
IUPUI, Team S2-G2, Harley Spring 2018 IUPUI, Team S2-G2, Harley Spring 2018 회원
IUPUI-HARLEY-S18S2G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 17
전체 시간: 501
