소개
The motherboard contains most of the electrical components of the device. It is a delicate piece of hardware but can easily be removed.
필요한 것
Pry the seam between the screen and the case and slide it on all four sides with a large plastic opening tool until the plastic case comes off.
이 단계에 사용된 도구:Plastic Cards$2.99
Wedge a plastic card beneath the battery unit and wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
Remove the two 5mm screws attached to the top right and bottom left corners of the speaker
Using the ph#00 screwdriver, remove the four 5mm screws connecting the motherboard to the casing.
