주요 콘텐츠로 건너뛰기
Polaroid PMID701i 10 Panel Replacement
필요한 것
  1. Polaroid PMID701i 10 Panel Replacement, Panel: 1 단계, 이미지 1/2 Polaroid PMID701i 10 Panel Replacement, Panel: 1 단계, 이미지 2/2
    • Turn off and unplug the device before starting replacement.
    • Flip the device so that the screen faces down, with the back facing up.
    • The back panel attaches to the device with four 4.0mm long screws, one at each corner, indicated by the red circles in the picture.
    • Unscrew the four screws with a PH000 screwdriver.
  2. Polaroid PMID701i 10 Panel Replacement: 2 단계, 이미지 1/2 Polaroid PMID701i 10 Panel Replacement: 2 단계, 이미지 2/2
    • Flip the device over so that the screen faces up, and the back faces down.
    • Separate the front panel using the Opening Tool on a corner to create an opening.
    • Removing the frame for the first time may take a significant amount of force.
    • Run the tool along the seams of the device to open up all the sides.
  3. Polaroid PMID701i 10 Panel Replacement: 3 단계, 이미지 1/1
    • Removing the panel too quickly may damage the cable that attaches parts between the two panels.
    • Gently lift the top panel from the bottom panel.
  4. Polaroid PMID701i 10 Panel Replacement: 4 단계, 이미지 1/2 Polaroid PMID701i 10 Panel Replacement: 4 단계, 이미지 2/2
    • The flexible flat cables (FFC) attach to parts in the bottom panel with zero insertion force (ZIF) connectors.
    • Use the Opening tool to flip up the black retaining flap on the smaller connector.
    • Gently lift the cable, parallel to the panel, to detach it.
  5. Polaroid PMID701i 10 Panel Replacement: 5 단계, 이미지 1/2 Polaroid PMID701i 10 Panel Replacement: 5 단계, 이미지 2/2
    • Use the Opening tool to flip up the black retaining flap on the larger connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Amy Li
회원 가입일: 01/31/17
627 평판
안내서 5개 작성하였습니다
Baylor, Team 3-4, Whitney Spring 2017 Baylor, Team 3-4, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 124
