소개
If the screen fails to display properly, consider using this guide to replace it.
필요한 것
Flip the device so that the screen faces down, with the back facing up.
Unscrew the four screws with a PH000 screwdriver.
Set the top panel down so that the interior faces up, and the exterior of the screen faces down.
Using the Opening Tool, gently lift up each of the snaps to release the screen from the panel.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
In terms of removing the screen, we found the plastic opening tool didn't help to lift the snaps to release the screen from the panel. It worked better when we used our hands to snap it out.
Megan Rule - 답글
