주요 콘텐츠로 건너뛰기
Polaroid PMID701i 10 Screen Replacement
필요한 것
  1. Polaroid PMID701i 10 Screen Replacement, Panel: 1 단계, 이미지 2개 중 1개 Polaroid PMID701i 10 Screen Replacement, Panel: 1 단계, 이미지 2개 중 2개
    • Turn off and unplug the device before starting replacement.
    • Flip the device so that the screen faces down, with the back facing up.
    • The back panel attaches to the device with four 4.0mm long screws, one at each corner, indicated by the red circles in the picture.
    • Unscrew the four screws with a PH000 screwdriver.
  2. Polaroid PMID701i 10 Screen Replacement: 2 단계, 이미지 2개 중 1개 Polaroid PMID701i 10 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the device over so that the screen faces up, and the back faces down.
    • Separate the front panel using the Opening Tool on a corner to create an opening.
    • Removing the frame for the first time may take a significant amount of force.
    • Run the tool along the seams of the device to open up all the sides.
  3. Polaroid PMID701i 10 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Removing the panel too quickly may damage the cable that attaches parts between the two panels.
    • Gently lift the top panel from the bottom panel.
  4. Polaroid PMID701i 10 Screen Replacement: 4 단계, 이미지 2개 중 1개 Polaroid PMID701i 10 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • The flexible flat cables (FFC) attach to parts in the bottom panel with zero insertion force (ZIF) connectors.
    • Use the Opening tool to flip up the black retaining flap on the smaller connector.
    • Gently lift the cable, parallel to the panel, to detach it.
  5. Polaroid PMID701i 10 Screen Replacement: 5 단계, 이미지 2개 중 1개 Polaroid PMID701i 10 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Use the Opening tool to flip up the black retaining flap on the larger connector.
  6. Polaroid PMID701i 10 Screen Replacement, Screen: 6 단계, 이미지 3개 중 1개 Polaroid PMID701i 10 Screen Replacement, Screen: 6 단계, 이미지 3개 중 2개 Polaroid PMID701i 10 Screen Replacement, Screen: 6 단계, 이미지 3개 중 3개
    • Set the top panel down so that the interior faces up, and the exterior of the screen faces down.
    • The screen attaches to to the panel with six black plastic snaps.
    • Using the Opening Tool, gently lift up each of the snaps to release the screen from the panel.
    • If a snap does not release when using the tool, attempt to lift it by hand.
  7. Polaroid PMID701i 10 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the screen from the frame by lifting it from the side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Amy Li
회원 가입일: 01/31/17
627 평판
안내서 5개를 작성함
Baylor, Team 3-4, Whitney Spring 2017 Baylor, Team 3-4, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G4
3 회원들
안내서 10개를 작성함
댓글 한 개
In terms of removing the screen, we found the plastic opening tool didn't help to lift the snaps to release the screen from the panel. It worked better when we used our hands to snap it out.
Megan Rule - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 281
