주요 콘텐츠로 건너뛰기
Polaroid PTAB7XC Power Button Replacement
필요한 것
  1. Polaroid PTAB7XC Power Button Replacement, Power Button: 1 단계, 이미지 2개 중 1개 Polaroid PTAB7XC Power Button Replacement, Power Button: 1 단계, 이미지 2개 중 2개
    • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver by turning them counterclockwise.
    • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
  2. Polaroid PTAB7XC Power Button Replacement: 2 단계, 이미지 2개 중 1개 Polaroid PTAB7XC Power Button Replacement: 2 단계, 이미지 2개 중 2개
    • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
    • The plastic case is now free from the device.
    • The plastic power button may or may not fall out at this point. There is no problem if it does.
  3. Polaroid PTAB7XC Power Button Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to push on the side of the black plastic power button that is outside of the device case until the button is as far in as possible.
    • Pull on the part of the broken power button that is exposed on the inside of the device case using tweezers until the button itself comes loose of the case.
    • The power button is now replaceable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Meg Lybbert
회원 가입일: 10/08/15
649 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 5
전체 시간: 1,009
