주요 콘텐츠로 건너뛰기
Polaroid S10 Battery Replacement
필요한 것
  1. Polaroid S10 Battery Replacement, Removing the backcover: 1 단계, 이미지 1/3 Polaroid S10 Battery Replacement, Removing the backcover: 1 단계, 이미지 2/3 Polaroid S10 Battery Replacement, Removing the backcover: 1 단계, 이미지 3/3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Battery Replacement, Battery: 2 단계, 이미지 1/3 Polaroid S10 Battery Replacement, Battery: 2 단계, 이미지 2/3 Polaroid S10 Battery Replacement, Battery: 2 단계, 이미지 3/3
    • Use a spudger to carefully remove the tape nearest to the battery.
    • Use caution while removing tape. Too much force can damage the device.
    • Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
    • Do not move the battery. Moving it could cause the cables to be ripped out.
  3. Polaroid S10 Battery Replacement, Battery Connection: 3 단계, 이미지 1/2 Polaroid S10 Battery Replacement, Battery Connection: 3 단계, 이미지 2/2
    • Carefully desolder the 2 wires that connect the battery to the motherboard.
    • Do not touch the soldering iron to the motherboard or the LCD screen.
결론
Follow these instructions to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
James
회원 가입일: 03/16/15
367 평판
안내서 3개 작성하였습니다
Colorado Springs, Team 1-4, May Spring 2015 Colorado Springs, Team 1-4, May Spring 2015 회원
UCCS-MAY-S15S1G4
4 회원들
안내서 13개 작성하였습니다
댓글 한 개
Can't open the %#*@ thing!!!!!!!!!!
tosaguys - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 5,158
