필요한 것
Place an opening pick between the volume button and the back cover.
Carefully remove the back cover using the metal spudger.
Use the spudger to remove the tape.
Remove the 2 J000 4 mm screws using a J000 screwdriver.
Carefully disconnect the connector port.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
