주요 콘텐츠로 건너뛰기
Polaroid S7 Digitizer Replacement
필요한 것
  1. Polaroid S7 Digitizer Replacement, Remove the back: 1 단계, 이미지 1/2 Polaroid S7 Digitizer Replacement, Remove the back: 1 단계, 이미지 2/2
    • Insert the flat end of one of the plastic opening tools between the screen and the colored back cover. Gently pry apart the pieces.
    • Carefully separate the screen from the back, taking care not to rip the ribbons connecting them.
  2. Polaroid S7 Digitizer Replacement: 2 단계, 이미지 1/2 Polaroid S7 Digitizer Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the wedge and pry it open.
  3. Polaroid S7 Digitizer Replacement: 3 단계, 이미지 1/1
    • Open the latch and pull to remove the LCD.
  4. Polaroid S7 Digitizer Replacement, Digitizer: 4 단계, 이미지 1/1
    • After you remove the digitizer, open the latch and remove the screen.
  5. Polaroid S7 Digitizer Replacement: 5 단계, 이미지 1/1
    • To install the new screen, insert the digitizer into the new screen and latch them back in.
결론
Thiago Guedes
회원 가입일: 01/20/15
17 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-2, Blackwell Winter 2015 USF Tampa, Team 1-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 168
