주요 콘텐츠로 건너뛰기
Polaroid SNAP Paper Door Replacement
필요한 것
  1. Polaroid SNAP Paper Door Replacement, Paper Door: 1 단계, 이미지 1/1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Paper Door Replacement: 2 단계, 이미지 1/2 Polaroid SNAP Paper Door Replacement: 2 단계, 이미지 2/2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
  3. Polaroid SNAP Paper Door Replacement: 3 단계, 이미지 1/2 Polaroid SNAP Paper Door Replacement: 3 단계, 이미지 2/2
    • Turn rear face plate over.
  4. Polaroid SNAP Paper Door Replacement: 4 단계, 이미지 1/3 Polaroid SNAP Paper Door Replacement: 4 단계, 이미지 2/3 Polaroid SNAP Paper Door Replacement: 4 단계, 이미지 3/3
    • Maneuver the plastic paper door out of the sockets one at a time. Make sure to be gentle so the plastic does not snap. Also, make sure to keep track of the small springs.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ian Colantuoni
회원 가입일: 02/09/16
619 평판
안내서 2개 작성하였습니다
USF Tampa, Team 7-3, Cheng Spring 2016 USF Tampa, Team 7-3, Cheng Spring 2016 회원
USFT-CHENG-S16S7G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 30
전체 시간: 6,823
