주요 콘텐츠로 건너뛰기
Polaroid SNAP View Finder Replacement
필요한 것
  1. Polaroid SNAP View Finder Replacement, Polaroid SNAP Front and Back Face Plate Removal: 1 단계, 이미지 1/1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP View Finder Replacement: 2 단계, 이미지 1/2 Polaroid SNAP View Finder Replacement: 2 단계, 이미지 2/2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP View Finder Replacement: 3 단계, 이미지 1/2 Polaroid SNAP View Finder Replacement: 3 단계, 이미지 2/2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP View Finder Replacement: 4 단계, 이미지 1/3 Polaroid SNAP View Finder Replacement: 4 단계, 이미지 2/3 Polaroid SNAP View Finder Replacement: 4 단계, 이미지 3/3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP View Finder Replacement: 5 단계, 이미지 1/1
    • The cameras innards should now be accessible to you
  6. Polaroid SNAP View Finder Replacement, View Finder: 6 단계, 이미지 1/2 Polaroid SNAP View Finder Replacement, View Finder: 6 단계, 이미지 2/2
    • Gently grasp the view finder (while in the closed position) with your thumb and fore finger. Then carefully pull the viewfinder outwards.
  7. Polaroid SNAP View Finder Replacement: 7 단계, 이미지 1/2 Polaroid SNAP View Finder Replacement: 7 단계, 이미지 2/2
    • Once the view finder is out, a small black tab should come loose from the viewfinder. Insert this small black tab in to the hole on the side of the new view finder, with the round side up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Austin Broyles
회원 가입일: 02/09/16
249 평판
안내서 2개 작성하였습니다
USF Tampa, Team 7-3, Cheng Spring 2016 USF Tampa, Team 7-3, Cheng Spring 2016 회원
USFT-CHENG-S16S7G3
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Where can I buy a replacement viewfinder for this camera?
Shelby Sisk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 20
전체 시간: 3,465
