주요 콘텐츠로 건너뛰기
Polaroid Sun 600 LMS Film Pack Replacement
  1. Polaroid Sun 600 LMS Film Pack Replacement, Film Pack: 1 단계, 이미지 1/1
    • Locate film door and slide release latch.
    • The slide release is near the lower left corner towards the front of the camera.
  2. Polaroid Sun 600 LMS Film Pack Replacement: 2 단계, 이미지 1/1
    • Slide side latch towards the front of camera.
    • The film door will pop open.
  3. Polaroid Sun 600 LMS Film Pack Replacement: 3 단계, 이미지 1/1
    • Insert film pack.
    • Make sure the battery contacts on the film pack are facing down and in contact with the camera's contacts.
  4. Polaroid Sun 600 LMS Film Pack Replacement: 4 단계, 이미지 1/1
    • Close film door by gently pushing it back into place.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Lessig
회원 가입일: 01/20/10
63 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-18, Maness Winter 2010 Cal Poly, Team 3-18, Maness Winter 2010 회원
CPSU-MANESS-W10S3G18
4 회원들
안내서 4개 작성하였습니다
댓글 3개
Where would you buy the sun 600 LMS battery film?
Albert Einstein - 답글
Where can I buy Sun 600 LMS instant battery film?
How do you fix the flash
Edward Flores - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 12,117
