이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Move film door slide on the left side of camera forward.
Pull film door open.
Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
Use a spudger on each side to separate the flash segment from the main body.
Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
Place left hand on the gray section and right hand on the black section.
Pull the sections apart.
Carefully remove the damaged lens from the interior of the camera.
Replace with a new lens.
다른 한 분이 해당 안내서를 완성하였습니다.
