주요 콘텐츠로 건너뛰기
Polaroid Z2300 Battery Replacement
  1. Polaroid Z2300 Battery Replacement, Battery: 1 단계, 이미지 1/2 Polaroid Z2300 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the camera upside down and gently use your thumb to pull the hatch forward and then upwards.
    • Once you lift the hatch up you will see the battery.
  2. Polaroid Z2300 Battery Replacement: 2 단계, 이미지 1/2 Polaroid Z2300 Battery Replacement: 2 단계, 이미지 2/2
    • Once you see the battery, you will see a tab saying 'pull' attached to the battery. gently pull on it until the battery is removed from the camera.
    • You can pull the battery easily afterwards.
  3. Polaroid Z2300 Battery Replacement: 3 단계, 이미지 1/1
    • Afterwards, you can easily reattach the battery back.
결론
Jasem Almeeli
회원 가입일: 03/02/17
101 평판
안내서 1개 작성함
USF Tampa, Team S13-G1, Cagle Spring 2017 USF Tampa, Team S13-G1, Cagle Spring 2017 회원
USFT-CAGLE-S17S13G1
4 회원들
안내서 2개 작성하였습니다
댓글 한 개
Do you know where to find a replacement battery? I’ve looked all over the internet.
Wendy Ralph - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 42
전체 시간: 3,835
