주요 콘텐츠로 건너뛰기
Polaroid Z2300 Control Panel Replacement
필요한 것
  1. Polaroid Z2300 Control Panel Replacement, Control Panel Replacement: 1 단계, 이미지 1/3 Polaroid Z2300 Control Panel Replacement, Control Panel Replacement: 1 단계, 이미지 2/3 Polaroid Z2300 Control Panel Replacement, Control Panel Replacement: 1 단계, 이미지 3/3
    • Locate and remove the two 2.5 mm long screws on the bottom of the camera.
    • Screw head: JIS J00
    • The screws are very small, be careful not to strip or lose them!
  2. Polaroid Z2300 Control Panel Replacement: 2 단계, 이미지 1/3 Polaroid Z2300 Control Panel Replacement: 2 단계, 이미지 2/3 Polaroid Z2300 Control Panel Replacement: 2 단계, 이미지 3/3
    • Once the two screws are removed, flip the camera to back side up.
    • Use a plastic opening tool to disengage the outer plastic trim until it can be safely removed.
  3. Polaroid Z2300 Control Panel Replacement: 3 단계, 이미지 1/2 Polaroid Z2300 Control Panel Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to pop the control panel off, it should be easy to lift up and remove.
결론
Bradley Marcum
회원 가입일: 11/01/18
217 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G1, Harley Fall 2018 IUPUI, Team S2-G1, Harley Fall 2018 회원
IUPUI-HARLEY-F18S2G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 8
전체 시간: 376
