주요 콘텐츠로 건너뛰기
Polaroid Z2300 Screen Replacement
필요한 것
  1. Polaroid Z2300 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Flip the camera to back side up and open the paper/screen door.
  2. Polaroid Z2300 Screen Replacement: 2 단계, 이미지 1/3 Polaroid Z2300 Screen Replacement: 2 단계, 이미지 2/3 Polaroid Z2300 Screen Replacement: 2 단계, 이미지 3/3
    • Locate and remove the two 3.5 mm long screws on the inside tray.
    • Screw head: JIS J00
    • Remove the inside tray.
    • The screws are very small! Be careful not to strip or lose them.
  3. Polaroid Z2300 Screen Replacement: 3 단계, 이미지 1/2 Polaroid Z2300 Screen Replacement: 3 단계, 이미지 2/2
    • Gently pull the ribbon away from the logic board. This will allow the screen to separate from the rest of the camera.
  4. Polaroid Z2300 Screen Replacement: 4 단계, 이미지 1/2 Polaroid Z2300 Screen Replacement: 4 단계, 이미지 2/2
    • Locate and remove four 3.5 mm long screws on the inside of the door.
  5. Polaroid Z2300 Screen Replacement: 5 단계, 이미지 1/1
    • Once the panel is removed, the malfunctioning screen will slide out and can be replaced.
결론
Bradley Marcum
회원 가입일: 11/01/18
217 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G1, Harley Fall 2018 IUPUI, Team S2-G1, Harley Fall 2018 회원
IUPUI-HARLEY-F18S2G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Where can I buy a replacement screen please?
mooi1uk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 415
