주요 콘텐츠로 건너뛰기
Polaroid i533 Button Replacement
필요한 것
  1. Polaroid i533 Button Replacement, Button: 1 단계, 이미지 1/3 Polaroid i533 Button Replacement, Button: 1 단계, 이미지 2/3 Polaroid i533 Button Replacement, Button: 1 단계, 이미지 3/3
    • Using a #00 screw driver, remove all of the screws on the body of the camera. There are 9 screws total on the face of the camera
    • All of the screws used in the Polaroid i533 are the same size
    • Be sure to not misplace any screws as you will need them to put the camera back together.
  2. Polaroid i533 Button Replacement: 2 단계, 이미지 1/2 Polaroid i533 Button Replacement: 2 단계, 이미지 2/2
    • Slide open the battery door, then using the plastic opening tool, slightly open the side of the camera case.
    • Gently pull apart the cover from the body of the camera.
    • Do not pull the cover off completely because it is still attached to the logic board.
  3. Polaroid i533 Button Replacement: 3 단계, 이미지 1/3 Polaroid i533 Button Replacement: 3 단계, 이미지 2/3 Polaroid i533 Button Replacement: 3 단계, 이미지 3/3
    • Locate the black tab where the LCD screen ribbon is attached to the logic board.
    • Using the plastic opening tool, flip the black tab towards the ribbon.
    • Gently pull the ribbon away from the logic board.
  4. Polaroid i533 Button Replacement: 4 단계, 이미지 1/1
    • The back half of the camera with the LCD screen should now be separated from the front casing.
    • If you are experiencing problems with your menu buttons, you must replace the entire back half of the outer case (Not including the screen). move on to step 5.
    • If you are experiencing problems only with your snap button (the one that you push to take pictures), skip ahead to step 7.
  5. Polaroid i533 Button Replacement: 5 단계, 이미지 1/1
    • Using a #00 screwdriver, remove the four screws located at each corner of the LCD screen.
  6. Polaroid i533 Button Replacement: 6 단계, 이미지 1/1
    • Remove the LCD screen from the old casing.
    • attach the LCD screen to the new casing using the screws removed in step 5.
  7. Polaroid i533 Button Replacement: 7 단계, 이미지 1/2 Polaroid i533 Button Replacement: 7 단계, 이미지 2/2
    • Using a #00 screw driver, remove the screw on the bottom of the logic board just above the tripod attachment.
    • Gently pull the front of the case away from the insides of the camera.
  8. Polaroid i533 Button Replacement: 8 단계, 이미지 1/2 Polaroid i533 Button Replacement: 8 단계, 이미지 2/2
    • Locate the button that will be removed.
    • To remove: gently push outward on the button from the inside of the casing.
  9. Polaroid i533 Button Replacement: 9 단계, 이미지 1/1
    • Remove spring from bottom of broken button.
    • Remove and replace defective button.
    • Do not lose spring as it is needed for replacement button.
결론
Terichael Office
회원 가입일: 06/24/10
9 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-4, Johann Summer 2010 Cal Poly, Team 3-4, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 2,390
