주요 콘텐츠로 건너뛰기
Polaroid i533 Outer Case Replacement
필요한 것
  1. Polaroid i533 Outer Case Replacement, Outer Case: 1 단계, 이미지 2개 중 1개 Polaroid i533 Outer Case Replacement, Outer Case: 1 단계, 이미지 2개 중 2개
    • Unscrew and remove the four screws from the left side of the camera (from the screen's view)
  2. Polaroid i533 Outer Case Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew and remove the three screws from the bottom of the camera
  3. Polaroid i533 Outer Case Replacement: 3 단계, 이미지 2개 중 1개 Polaroid i533 Outer Case Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew and remove the two screws from the right side of the camera.
  4. Polaroid i533 Outer Case Replacement: 4 단계, 이미지 2개 중 1개 Polaroid i533 Outer Case Replacement: 4 단계, 이미지 2개 중 2개
    • Open the battery flap and remove the batteries.
    • Keep the battery flap open.
  5. Polaroid i533 Outer Case Replacement: 5 단계, 이미지 1개 중 1개
    • Use a spudger to gently separate the two halves of the camera's outer casing.
  6. Polaroid i533 Outer Case Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull the half of the case with the screen (the back half) from the rest of the camera.
    • Be sure not too pull to hard. The screen is still attached to the motherboard. If you pull too hard you will rip it.
  7. Polaroid i533 Outer Case Replacement: 7 단계, 이미지 2개 중 1개 Polaroid i533 Outer Case Replacement: 7 단계, 이미지 2개 중 2개
    • The back half (the half with the screen on it) should now be separate from the rest of the camera, but still attached by the ribbon.
  8. Polaroid i533 Outer Case Replacement: 8 단계, 이미지 2개 중 1개 Polaroid i533 Outer Case Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to lift the black flap that clamps the ribbon towards you.
    • When the black flap is open it will be straight up. (like in the second picture)
  9. Polaroid i533 Outer Case Replacement: 9 단계, 이미지 1개 중 1개
    • Now that the black flap is open, gently pull the ribbon out.
    • You should now have the back half of the camera completely separate from the rest of the camera.
  10. Polaroid i533 Outer Case Replacement: 10 단계, 이미지 2개 중 1개 Polaroid i533 Outer Case Replacement: 10 단계, 이미지 2개 중 2개
    • This is what the back half of the camera should look like.
    • This is what the rest of the camera will look like.
  11. Polaroid i533 Outer Case Replacement: 11 단계, 이미지 1개 중 1개
    • Unscrew and remove two screws from the logic board.
  12. Polaroid i533 Outer Case Replacement: 12 단계, 이미지 1개 중 1개
    • Pull the front half off of the logic board.
  13. Polaroid i533 Outer Case Replacement: 13 단계, 이미지 1개 중 1개
    • This will be the front half of the outer case.
결론
작성자
4다른 기여자 명과 함께
Terichael Office
회원 가입일: 06/24/10
9 평판
안내서 2개를 작성함
Cal Poly, Team 3-4, Johann Summer 2010 Cal Poly, Team 3-4, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G4
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 1,540
