주요 콘텐츠로 건너뛰기
Polk MagniFi Soundbar Bluetooth Cable Replacement
필요한 것
  1. Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: 1 단계, 이미지 1/3 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: 1 단계, 이미지 2/3 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: 1 단계, 이미지 3/3
    • To reveal the control button, first, carefully remove the front cover of the Sound Bar.
    • Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
    • After the cover is fully removed, it will be able to see the interior speaker.
    • Carefully unscrew all 16 screws to release the panel.
    • There are total 16 screws that secures the panel onto the cover. Each screw is approximately 1.50 centimeter.
  2. Polk MagniFi Soundbar Bluetooth Cable Replacement: 2 단계, 이미지 1/3 Polk MagniFi Soundbar Bluetooth Cable Replacement: 2 단계, 이미지 2/3 Polk MagniFi Soundbar Bluetooth Cable Replacement: 2 단계, 이미지 3/3
    • To remove the cover behind the control buttons, insert the iFixit opening tool between the cover and the body
    • Push the opening tool along the edge of the cover to fully open it.
  3. Polk MagniFi Soundbar Bluetooth Cable Replacement: 3 단계, 이미지 1/1
    • Underneath the cover, there is a black panel screwed onto the cover with two sets of wires plugged into it.
  4. Polk MagniFi Soundbar Bluetooth Cable Replacement: 4 단계, 이미지 1/2 Polk MagniFi Soundbar Bluetooth Cable Replacement: 4 단계, 이미지 2/2
    • Grasp the wire firmly close to the base and pull straight out. Repeat this for the other end of the wire.
    • This wire is easily broken. Handle with care.
결론
[deleted]
회원 가입일: 10/22/18
671 평판
안내서 4개 작성하였습니다
댓글 한 개
Can you pair it with Beats headphones.?
wayne rivers - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 28
전체 시간: 2,421
