소개
If your soundbar is working but you are unable to control the power or volume with the buttons on top of the soundbar they may be stuck. Follow this guide to remove any dust.
필요한 것
To reveal the control button, first, carefully remove the front cover of the Sound Bar.
Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
After the cover is fully removed, it will be able to see the interior speaker.
Remove all screws from the front surface. all screws are approximately 1.50 centimeters.
댓글 한 개
My pollk is working but there is no sound coming out it connect the Bluetooth and wifi but my problem is there is no sound coming
