소개
Sometimes users have trouble with static on their phone meaning the connection between the handset and base may be faulty. This guide shows how to replace the antenna on the base of the phone.
필요한 것
Inside the base cover, locate the screw holding the antenna in place and use a Philips #00 screwdriver to remove the 6mm screw.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
