소개
A common problem users have with this phone is difficulty locating and replacing the battery. This guide will take you through the steps of finding and replacing the battery.
Hold the mouthpiece of the handset and locate the lock-unlock text.
Twist the battery cover counterclockwise from the "lock" to the "unlock" position.
To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket.
다른 2명이 해당 안내서를 완성하였습니다.
