주요 콘텐츠로 건너뛰기
Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement
필요한 것
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: 1 단계, 이미지 1/3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: 1 단계, 이미지 2/3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: 1 단계, 이미지 3/3
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Screws to Base Plate: 2 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: 3 단계, 이미지 1/3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: 3 단계, 이미지 2/3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: 3 단계, 이미지 3/3
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jay Gunter
회원 가입일: 10/27/14
378 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 390
