주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pool Screen Replacement
필요한 것
  1. Pool Screen Replacement, Damaged screen area: 1 단계, 이미지 1개 중 1개
    • Locate the damaged area on your screen. Use this area to remove the rest of the screen. Using an area that is already damaged makes it easier to remove the old screen.
    댓글 쓰기
  2. Pool Screen Replacement, Removing the screen and thread: 2 단계, 이미지 2개 중 1개 Pool Screen Replacement, Removing the screen and thread: 2 단계, 이미지 2개 중 2개
    • Use needle nose pliers to pull the rubber screen thread from the pool cage crease.
    • To help remove the damaged screen, pull down on the screen while you are removing the thread of the old screen.
    댓글 쓰기
  3. Pool Screen Replacement, Checking for leftover thread: 3 단계, 이미지 1개 중 1개
    • Examine your work. It should match the image as shown.
    • There should be no thread left in the crease of the pool cage. Remove any remaining screen thread with the needle nose pliers.
    댓글 쓰기
  4. Pool Screen Replacement, Measuring the screen: 4 단계, 이미지 1개 중 1개
    • Measure the area of the pool cage that needs to be replaced with a new roll of screen. Cut out the needed amount of screen from the new roll.
    • Do not cut the excess screen on the sides of the pool cage; it will be done in a later step.
    댓글 쓰기
  5. Pool Screen Replacement, Placing the thread and screen: 5 단계, 이미지 2개 중 1개 Pool Screen Replacement, Placing the thread and screen: 5 단계, 이미지 2개 중 2개
    • Pull the new screen thread from corner to corner, along the crease of the pool cage. Cut any excess thread from the corners.
    • Use a screen roller to press the thread and the screen underneath against the pool cage crease to secure them. It helps to pull the thread and screen tight while rolling over it.
    • The roller pictured is available at any home improvement store. It will be located next to the pool screens and thread.
    댓글 쓰기
  6. Pool Screen Replacement, Removing extra screen: 6 단계, 이미지 1개 중 1개
    • Cut the excess screen from the top, bottom, and sides of the pool cage.
    • Be careful when using the box cutter. Always cut away from your body in order to avoid injury.
    댓글 쓰기
  7. Pool Screen Replacement, Finishing up: 7 단계, 이미지 2개 중 1개 Pool Screen Replacement, Finishing up: 7 단계, 이미지 2개 중 2개
    • Check the pool cage for any problems with the newly attached screen. The new thread should be pressed firmly into the pool cage, and the screen should be pulled tight so there are no wrinkles.
    댓글 쓰기
결론
With this guide, you will be able to repair your damaged pool screen. Follow the steps, and you will have a new screen in no time.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
13다른 기여자 명과 함께
Haley Flanigan
회원 가입일: 01/17/17
121 평판
안내서 1개를 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 회원
USFSM-STEWART-S17S1G1
19 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 79
전체 시간: 8,181
