주요 콘텐츠로 건너뛰기
Pop-Up Assembly Stopper Piece Replacement
필요한 것
  1. Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: 1 단계, 이미지 1/2 Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: 1 단계, 이미지 2/2
    • Place bucket directly under the sink below the pop-up assembly. Excess water may leak
    • The pivot rod that is inserted within a hole in the pop-up extension bar. Move the pop-up extension bar away from the pivot rod.
  2. Pop-Up Assembly Stopper Piece Replacement: 2 단계, 이미지 1/1
    • Disconnect the pivot rod from the center pop-up extension.
  3. Pop-Up Assembly Stopper Piece Replacement: 3 단계, 이미지 1/2 Pop-Up Assembly Stopper Piece Replacement: 3 단계, 이미지 2/2
    • Lift up the center pop-up rod on the faucet until it is detached. The extension rod will pull up with it.
  4. Pop-Up Assembly Stopper Piece Replacement: 4 단계, 이미지 1/3 Pop-Up Assembly Stopper Piece Replacement: 4 단계, 이미지 2/3 Pop-Up Assembly Stopper Piece Replacement: 4 단계, 이미지 3/3
    • Below the sink is the pivot nut. Turn the pivot nut counterclockwise until it is completely loose and remove from the pivot rod.
  5. Pop-Up Assembly Stopper Piece Replacement: 5 단계, 이미지 1/2 Pop-Up Assembly Stopper Piece Replacement: 5 단계, 이미지 2/2
    • Pull the pivot rod out to expose the ball. Remove the whole pivot rod fixture.
  6. Pop-Up Assembly Stopper Piece Replacement: 6 단계, 이미지 1/2 Pop-Up Assembly Stopper Piece Replacement: 6 단계, 이미지 2/2
    • In the sink, the pop-up stopper will be loose.
    • Pull up on the pop-up stopper to separate it from the main pop-up assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brenna Stafford
회원 가입일: 10/07/19
160 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 63
전체 시간: 1,443
