소개
Before beginning this repair guide, be sure to unplug the charger from the computer and handle the battery with care. Avoid using sharp metal objects around the battery when ever possible. After finishing this guide you should notice a considerable battery life extension to your computer after being unplugged.
필요한 것
Flip the laptop over with the screen facing down to reveal the bottom panel.
Unscrew each of the highlighted screws with a Phillips #0 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
can we still run it without battery? i mean using direct power supply and no battery install
