주요 콘텐츠로 건너뛰기
Portege Z830-S8302 Battery Replacement
필요한 것
  1. Portege Z830-S8302 Battery Replacement, Battery: 1 단계, 이미지 1/3 Portege Z830-S8302 Battery Replacement, Battery: 1 단계, 이미지 2/3 Portege Z830-S8302 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop over with the screen facing down to reveal the bottom panel.
    • Unscrew each of the highlighted screws with a Phillips #0 screwdriver.
  2. Portege Z830-S8302 Battery Replacement: 2 단계, 이미지 1/3 Portege Z830-S8302 Battery Replacement: 2 단계, 이미지 2/3 Portege Z830-S8302 Battery Replacement: 2 단계, 이미지 3/3
    • Use a metal spudger to remove fitting and reveal the screw.
    • Use a screwdriver with a Torx T7 bit to remove the screw.
  3. Portege Z830-S8302 Battery Replacement: 3 단계, 이미지 1/3 Portege Z830-S8302 Battery Replacement: 3 단계, 이미지 2/3 Portege Z830-S8302 Battery Replacement: 3 단계, 이미지 3/3
    • The SD Card slot is on the top right corner of the device near the headphone jacks.
    • Depress the fake SD Card and release.
    • Pull the fake SD Card out and remove it completely from the slot, as this will help in the removal of the backplate.
  4. Portege Z830-S8302 Battery Replacement: 4 단계, 이미지 1/2 Portege Z830-S8302 Battery Replacement: 4 단계, 이미지 2/2
    • Lift the back plate starting at the opposing edge to the SD card. Lift from left to right and continue lifting this plate at this angle until it's free from the laptop.
    • Once the backplate is completely off, this will reveal the inside components of the device.
    • Upon reassembly of the back cover, make sure to line up the two headphone jacks on the upper right corner with the holes in the back cover or else it will not seat fully.
  5. Portege Z830-S8302 Battery Replacement: 5 단계, 이미지 1/3 Portege Z830-S8302 Battery Replacement: 5 단계, 이미지 2/3 Portege Z830-S8302 Battery Replacement: 5 단계, 이미지 3/3
    • The battery is the black rectangular piece in the bottom half of the device.
    • Remove six 5mm screws holding down the battery using a Phillips PH0 screwdriver.
    • Lift the battery and separate from its place holder.
    • Do not fully remove the battery as it is still connected by the connector in the top right corner.
  6. Portege Z830-S8302 Battery Replacement: 6 단계, 이미지 1/3 Portege Z830-S8302 Battery Replacement: 6 단계, 이미지 2/3 Portege Z830-S8302 Battery Replacement: 6 단계, 이미지 3/3
    • Using the nylon spudger, disconnect the white plugin.
    • Once the wire has been disconnected you may remove the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tanner Krygier
회원 가입일: 09/17/18
913 평판
안내서 5개 작성하였습니다
Washington State, Team S2-G7, Hope Fall 2018 Washington State, Team S2-G7, Hope Fall 2018 회원
WSU-HOPE-F18S2G7
3 회원들
안내서 15개 작성하였습니다
댓글 한 개
can we still run it without battery? i mean using direct power supply and no battery install
hairu nizam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 14
전체 시간: 724
