주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Flip the laptop over with the screen facing down to reveal the bottom panel. Unscrew each of the highlighted screws with a Phillips #0 screwdriver. Unscrew each of the highlighted screws with a Phillips #0 screwdriver.
    • Flip the laptop over with the screen facing down to reveal the bottom panel.
    • Unscrew each of the highlighted screws with a Phillips #0 screwdriver.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a metal spudger to remove fitting and reveal the screw. Use a screwdriver with a Torx T7 bit to remove the screw. Use a screwdriver with a Torx T7 bit to remove the screw.
    • Use a metal spudger to remove fitting and reveal the screw.
    • Use a screwdriver with a Torx T7 bit to remove the screw.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    The SD Card slot  is on the top right corner of the device near the headphone jacks. Depress the fake SD Card and release. Pull the fake SD Card out and remove it completely from the slot, as this will help in the removal of the backplate.
    • The SD Card slot is on the top right corner of the device near the headphone jacks.
    • Depress the fake SD Card and release.
    • Pull the fake SD Card out and remove it completely from the slot, as this will help in the removal of the backplate.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lift the back plate starting at the opposing edge to the SD card. Lift from left to right and continue lifting this plate at this angle until it's free from the laptop. Once the backplate is completely off, this will reveal the inside components of the device.
    • Lift the back plate starting at the opposing edge to the SD card. Lift from left to right and continue lifting this plate at this angle until it's free from the laptop.
    • Once the backplate is completely off, this will reveal the inside components of the device.
    • Upon reassembly of the back cover, make sure to line up the two headphone jacks on the upper right corner with the holes in the back cover or else it will not seat fully.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    The battery is the black rectangular piece in the bottom half of the device. Remove six 5mm screws holding down the battery using a Phillips PH0 screwdriver. Lift the battery and separate from its place holder.
    • The battery is the black rectangular piece in the bottom half of the device.
    • Remove six 5mm screws holding down the battery using a Phillips PH0 screwdriver.
    • Lift the battery and separate from its place holder.
    • Do not fully remove the battery as it is still connected by the connector in the top right corner.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Using the nylon spudger, disconnect the white plugin. Once the wire has been disconnected you may remove the battery. Once the wire has been disconnected you may remove the battery.
    • Using the nylon spudger, disconnect the white plugin.
    • Once the wire has been disconnected you may remove the battery.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the two 5mm Phillips #0 screws from the fan housing. Remove the two 5mm Phillips #0 screws from the fan housing.
    • Remove the two 5mm Phillips #0 screws from the fan housing.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a nylon spudger to disconnect the wire (red/blue) plug from the motherboard. Be gentle and do not apply too much pressure when removing this plug as the motherboard may be fragile.
    • Use a nylon spudger to disconnect the wire (red/blue) plug from the motherboard.
    • Be gentle and do not apply too much pressure when removing this plug as the motherboard may be fragile.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lift up the wire and peel back the clear protective tape. Split the black protective foam inside the tape in half to uncover the wires.
    • Lift up the wire and peel back the clear protective tape.
    • Split the black protective foam inside the tape in half to uncover the wires.
    • This should make the wires free of all connections.
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    The fan is now free and able to be removed. Lift the fan out of place. The fan is now free and able to be removed. Lift the fan out of place.
    • The fan is now free and able to be removed. Lift the fan out of place.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the two Phillips #0 4mm screws from the heat sink. Lift and remove the heat sink off the CPU. Reapply thermal paste to the heat sink upon reassembly.
    • Remove the two Phillips #0 4mm screws from the heat sink.
    • Lift and remove the heat sink off the CPU.
    • Reapply thermal paste to the heat sink upon reassembly.
  12. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a plastic opening tool to disconnect the orange daughterboard cable and pull out of the connector. Do the same on other side of the orange cable and remove cable completely. Do the same on other side of the orange cable and remove cable completely.
    • Use a plastic opening tool to disconnect the orange daughterboard cable and pull out of the connector.
    • Do the same on other side of the orange cable and remove cable completely.
  13. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the clear tape covering the Wifi module. Remove the clear tape covering the Wifi module.
    • Remove the clear tape covering the Wifi module.
  14. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove one Phillips #0 3mm screw from the Wifi module. Disconnect the wifi module from the motherboard by gently sliding piece out of the port. Disconnect the wifi module from the motherboard by gently sliding piece out of the port.
    • Remove one Phillips #0 3mm screw from the Wifi module.
    • Disconnect the wifi module from the motherboard by gently sliding piece out of the port.
  15. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Using a plastic opening tool, disconnect the plug from the motherboard. Using a plastic opening tool, disconnect the plug from the motherboard. Using a plastic opening tool, disconnect the plug from the motherboard.
    • Using a plastic opening tool, disconnect the plug from the motherboard.
  16. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Using a nylon spudger, remove the CMOS battery connector cable (red/black) from its port. Using a nylon spudger, remove the CMOS battery connector cable (red/black) from its port. Using a nylon spudger, remove the CMOS battery connector cable (red/black) from its port.
    • Using a nylon spudger, remove the CMOS battery connector cable (red/black) from its port.
  17. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Using a nylon spudger, disconnect the cable from the motherboard. Using a nylon spudger, disconnect the cable from the motherboard. Using a nylon spudger, disconnect the cable from the motherboard.
    • Using a nylon spudger, disconnect the cable from the motherboard.
  18. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a plastic opening tool to disconnect the black ribbon from the motherboard. Use a plastic opening tool to disconnect the black ribbon from the motherboard. Use a plastic opening tool to disconnect the black ribbon from the motherboard.
    • Use a plastic opening tool to disconnect the black ribbon from the motherboard.
  19. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Using a plastic opening tool, disconnect the white cable from the port. Using a plastic opening tool, disconnect the white cable from the port. Using a plastic opening tool, disconnect the white cable from the port.
    • Using a plastic opening tool, disconnect the white cable from the port.
  20. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the screen data cable from its connector. Remove the screen data cable from its connector. Remove the screen data cable from its connector.
    • Remove the screen data cable from its connector.
  21. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Using a nylon spudger, disconnect the DC power plug connector at the top of the motherboard. Gently remove the whole piece from its  holder and place it aside. Gently remove the whole piece from its  holder and place it aside.
    • Using a nylon spudger, disconnect the DC power plug connector at the top of the motherboard.
    • Gently remove the whole piece from its holder and place it aside.
  22. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove one Phillips PH0 3mm screw from the top of the motherboard. Gently lift the motherboard out of its casing to fully remove from the device. Gently lift the motherboard out of its casing to fully remove from the device.
    • Remove one Phillips PH0 3mm screw from the top of the motherboard.
    • Gently lift the motherboard out of its casing to fully remove from the device.
결승점
Tanner Krygier
회원 가입일: 2018년 09월 17일
872 평판
안내서 5개 작성하였습니다
Washington State, Team S2-G7, Hope Fall 2018 Washington State, Team S2-G7, Hope Fall 2018 회원
WSU-HOPE-F18S2G7
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 30
전체 시간: 515
